Home Network
Home Network
Can anybody advise me on what is needed to set up a wireless network from
my main pc int he living room with 2mb broadband connecting to a 2nd pc in my sons bedroom, this room does not have a phone ext.
Any help and advice in the way of equipment would be much appreciated.
Home Network
I have today been and updated my system using this item that I got from Scan. www.scan.co.uk
Very easy to set up and will do the job you want.
Home Network
You could just buy a real long crossover network cable to go between the two pc's if you don’t mind having cables lying around. Best option is to buy a wireless router with a pci (internal) wireless adaptor.
Just an example a budget wireless router will set you back ~ £44.99 and the wireless adaptor ~ £19.99.
I have a Belkin setup here, its ok, does its job. My father in-law has the latest Netgear router and adaptor which i must say is very nice.
Make sure you get 802.11g grade kit, 54Mbps or 108Mbps its up too you.
2 PCs
Why not just buy a belkin USB bluetooth adapter for each PC - total cost £25/£30
If your son has a laptop it may well be bluetooth enabled which will save you the cost of one dongle.
Home Network
Whats the range on bluetooth? only about 5 - 10 meters i think.
Wont be as good as a router plus pci wireless card, if your going to build a home network it may aswell be done properly.
Home Network
Bluetooth can have up to 100m range
Home Network
I can personally vouch for the D-Link John linked you to.
I have used that exact model and I must admit it worked a treat. I have since gone a little loopy and extended my equipment and network, but for what you want, it will work great.
Home Network
Yep go for a router setup
