Help with setting up a Cisco 7960
Hi All
Is anyone using a Cisco 7960 IP Hard Phone with Plustalk or can assist in helping to get this phone working?
Phone firmware details
Application Load ID:
P0S3-08-6-00
Boot Load ID
PC030301
DSP Load ID
4.0(2.0)[A0]
Network details:
The Cisco 7960 is connected to my Linksys WRT54G which is connected to a D-Link DSL 300-T.
Administration
Line_1_Settings Name: Plusnet
Line_1_Settings Shortname: UNPROVISIONED
Line_1_Settings Authentication Name: SIP ID xxxxxx
Line_1_Settings Authentication Password: xxxxxxxxxxx
Line_1_Settings Display Name: Greg
Line_1_Settings Proxy Address: sip.plus.net
Line_1_Settings Proxy Port: 5060
Generic Settings
8. Preferred Codec: g711ulaw
9. Out of Band DTMF: avt
10. register with Proxy: YES
11. Register Expires: 3600
12. TFTP Dir.
13. Phone label: UNPROVISONED
14. Enable VAD: NO
15. VoIP Control Port: 5060
16. Start Media: 16384
17: End Media: 32766
18. Backup proxy: UNPROVISIONED
19. Backup proxy port: 5060
20. Emergency proxy: UNPROVISIONED
21. Emergency Proxy port: 5060
22. Outbound Proxy: sip.plus.net
23. Outbound Proxy Port: 5060
24: NAT Enabled: YES
25: NAT Address: xxx.xxx.xxx.xxx (current Plusnet address)
When I dial my home line under Status Messages I see:
E620 REG auth failed: no more credentials.
To me this looks like the phone is set-up ok, although I would like some input on the NAT administration and that this is an account issue?
Thanks Greg
1 REPLY
Looks like a NAT issue, I got x-lite working with STUN.
Cant find anywhere to program a STUN proxy in the 7960 Sad
Greg
