Help to link to images on webspace
hi
I have installed image viewer on my site and it works great without any cgi access to display all the images. However, I cant give anyone a link to a single image on the site. Is this possible with this account/plusnet?
You give them the web address and then add / plus the jpg file.
If you look at http:// www.janwright.co.uk you can see the menu at the top if I wanted to give you a link to the menu image I would use.
http://www.janwright.co.uk/menu.jpg
Thanks.
I'd heard some sites didnt allow that sort of thing so wasnt sure. in the end it turned out to be user error and I had tried to link the wrong filename
Thanks again
