Help me use ,spybot-search+destroy[freeware]
running seatch+destroy,keep getting[red]DSO Exploit-5 entries,I go to fix selected problems says its done,but when i scan again straight after its there again?Can some 1 help me and also tell me if they know what it is.
Spybot doesn't actually fix them, but they do have a note on the spybot website on how to resolve the issue, but it means updating the registry by hand.
If you happy to do this, then search within google for DSO exploit.
Aaron
it seems i,ll wait as there going to do a patch[in 1 of there updates].CHEERS anyway.
