Help ! ftp problems
Help ! ftp problems
Hi
I wonder if anyone could help me out on this, it's had me stuck for four days now Sad
I've uploaded some new pages to my website using my regular ftp software. Some of the pages are new some are just updates of old ones.
When i try to view them in Explorer all i'm seeing is the old pages, i've refreshed dozens of times & emptied out my temp files 3 or 4 times, i've even viewed them from a different machine, still the same problem.
So i go back to my ftp software & log into my webspace & view the files through that. The files showing ARE the updated ones & the new ones.
I'm at a complete loss Sad any help would be much appre
Help ! ftp problems
This will be an effect of the cache that PlusNet are using to overcome speed problems.
Read through this thread for an insight into the problem.
http://portal.plus.net/central/forums/viewtopic.php?t=13733
Help ! ftp problems
See Are users aware of the major changes to our web sites?.
It's a problem with the cache servers PlusNet have implemented, I suggest you read that and add your comments.
Help ! ftp problems
thanks for the heads up Wink
