Hacker Removal Help Wanted
I have recently run Spybot and it has indicated that I have a 'MySoft' problem and is sub divided into a 'sitefinder.verisign.com 127.0.0.1'.
Spybot has told me that it cannnot fix the problem and to restart my computer when it runs a scan befroe all the set up is started. This still does not fix the problem.
Can anybody advise me how I can remove the problem?.
In simple terms if possible as I am not very computer literate and I am on a learning curve.
Dave C
holdtight
it could be that the reason Spybot can't delete it is because of the host file being read only or locked by Spybot
find your hosts file and untick read only and unblock this file if the option is there
then run spybot again and see what it comes up with
i would also recommend installing adaware and running that also as one can miss something while the other will find it and vice versa
make sure that both are fully updated with the latest updates before running a scan
your hosts file can be found at C:\ windows\ system32\ drivers\ etc
What version of spybot are you running. If 1.3, try the latest beta 1.4b2 and see if that can fix it.
