HSBC Virus Notification
I understand that if a machine on my ADSL connection is transmitting on TCP port 135 then PlusNet will redirect me to a web page warning me about a possible virus infrection - all well and good.
However, can someone explain to me why I get redirected to this page when (and only when) I try to visit www.hsbc.co.uk - all other surfing, including www.hsbc.com, is fine.
Other machines on this connection are fine, so it is something to do with this individual machine.
I'm not aware of a virus or worm that only transmits when you visit a particular site?
(I'm currently running a full A/V scan as I type, however I was curious as to why only this one URL seems to be affected.)
Confoozed
D'Essen
Have you scanned for spyware/malware using Adaware and spybot search and destroy?
Have you tried other online vrus scanners (no virus scanner is 100% reliable in detecting all viruses).
Have you scanned for trojans?
Details of links to various apps to do the above can be found in General: Essential Security software.
Thanks for your advice.
I'm conscious that the AVG on the machine in question is not necessarily the greatest, so I have also also got a clean bill of health from HouseCall.
Adware also comes through clean! I'll have a look for Trojans now...
I'm still puzzled as to why it's only one website that I can't get hold of? I would have presumed that the PlusNet message would be indiscriminate to any particular site.
Regards,
D'Essen
It is possible accessing that site is triggering some software/virus/malware to attempt to make a connection on port 135 to a remote system. Sometimes key loggers do this when they record keystrokes and send the details to a remote system where things like logins/passwords can be extracted.
Bring up the Windows task manager and see if there are any apps tunning in the background that you are not familiar with - links to sites that describe what background apps do can be found in the security tutorial link I gave earlier.
Also when you run adaware / spybot, make sure you download the latest updates as both have been out for a while. The same applies to any AV software - make sure the virus defs are up to date.
Thanks again for your time.
In short, yes my definitions were up to date - I checked that before running any tests.
Everything, including the trojan scanner came through clean! And still no joy!
In the end, I cleared the local web-cache and that resolved the issue :roll: Wish I had thought of that in the first place! :!:
thanks
D'Essen
