HELP! Grandstream 486 Setup
Hello All. Can someone please please please help.
I am trying to get a Grandstream 486 adapter to work without much luck - just look at the time!
I have followed the instructions and enabled the WAN port. I have set its IP address in the DMZ area of the router but do I get anything? Do I heck.
The frustrating thing is that Xlite works fine. But that uses a different type of settings. For example it does not require the SIP ID number. Is there anyway of checking whether the values given to me by Plusnet are correct?
Suggestion welcome.
