Frontpage web space
Frontpage web space
I have uploaded a website, using FrontPage, and want to know how much space it is taking up.
I have looked at the My Webspace, but that only shows data from the www.username.plus.com, not fp.username.plus.com. I tsays I have used 0Mb, and I know that is false.
How can I find out how big the site is ?
Cheers
Neil :?:
Size
If you have an exact local copy of your site on your PC, check the folder by right clicking and selecting 'properties'.
Hope that helps.
Frontpage web space
And if you havent got a copy of your site on your PC then you should have.
If only as security so that if the unforseen happened you dont loose all your hard work
