Frequent Broadband Disconnection
Problem: Regular Disconnection
I am a new user of broadband but I find that every day for the past week, each time I connect, my connection goes off. Sometimes it works for half an hour or forty minutes and then suddenly it terminates and I am not able to get online again.
I reported this to the technical staff more than five times.
The first time was on a saturday and I was told it could be a BT line error as BT may be doing maintenance on the line. I was asked to try every hour but did not succeed.
The next day when I complained i was told to uninstall the modem and re instal, which I did. It started working for some hours but then later disconnected.
During the week every day it disconnected.
When I complained this saturday I was told to keep a log of the exact times that the connection breaks down, which is frustrating!
Can you figure out where the problem is?
Once it disconnects I cannot reconnect as the DSL icon says 'failed to initialize.'
This morning it connected for half an hour and then went dead.
Right now (10.00 p.m.) it is working. I do not know when it will go dead!
Any suggestions?
Thanks!
Jude
Can you tell us what type of modem you have.
If it is a router/modem combo unit, can you tell us the make, model and firmware version.
If it is a USB modem, what make and model is it. In adition, can you tell us what CPU you have, your memory size and the motherboard make and model.
this is exactly what im getting, dont klnow if this person had a USB dynamode wassamahoojit ( A360 thats it) but its the same problem the adsl just goes, the modem shuts down and refuses to light back up again untill i reboot, this is mentioned somewhere else by me, but as of yet i havnt solved it.
(windows ME, 1465 mhz AMD Athlon XP, 320 MB RAM, erm mobo is a new gigabyte not sure which though)
