Free webspace
Free webspace
Unfortunatly my site has been banned as i went over my bandwidth limit, so does anyone know where i can get about 200mb of free webspace
Free webspace
good luck
Free webspace
Free Huh?, with the bandwidth you want Huh
Sorry, pigs and flight spring to mind.
pcorker
Free webspace
open 15 freeserve accounts and split it :lol:
Pat.
Free webspace
I found some space. £49.99 per year. Looks good and its given me a 3 month trial first so that if i don't like it i can cancel.
michaelscott
Free webspace
what host is it with?
you might want to give machosting a try: http://www.macoman.co.uk/
Free webspace
i found a good host called DeepBlue Webhosting:
http://www.deepbluehosting.co.uk/
they seem to offer pretty reasonable packages, I havent found anything much better - though i guess it depends on exactly what space/bandwith you need
good luck Smiley
Free webspace
found some space and my new site is
www.bootlegsandbsides.co.uk
Free webspace
Your site title looks interesting - but the link doesn't work for me..
Free webspace
they banned you cause you went over the bandwith limit? do they ever unban you? or is it untill your bandwith gets reset? anyone, tim
Free webspace
Most probably went over bandwidth there as well.
Free webspace
I think they are having problems with the server. Its having an update or something.
Free webspace
Not only PlusNet having problems then
Free webspace
Well as far as i can gather my site is having problems. I cant log in using cute ftp (invalid password), cant view my site or check the sites mail.
If there was a problem, eg going over bandwidth, site removed etc i guess they would have contated me wouldnt they?
Free webspace
DNS doesn't return anything for www.bootlegsandbsides.co.uk or bootlegsandbsides.co.uk
