Fragmented traffic alarms
mssystems
Hi all
Over the last couple weeks my firewall has been Alarming (see below)
I have traced the subnet and can't think of a reason why it is trying to contact me. It also looks like my subnet is being sytematically scanned. So it is all rather suspicious.
I was wondering if anyone had any idea what application or trojan might be trying to connect on UDP 8224 and 1029 ?
I have blocked the culprits ISPs subnet and e-mailed the abuse address.
Regards
Matt
[00001] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.98.57:8224 to xxx.xxx.xxx.xx4:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
[00002] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.98.57:7223 to xxx.xxx.xxx.xx4:1029, proto UDP (zone Untrust, int untrust). Occurred 1 times.
[00003] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.98.248:8224 to xxx.xxx.xxx.xx5:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
[00004] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.98.248:18530 to xxx.xxx.xxx.xx5:1029, proto UDP (zone Untrust, int untrust). Occurred 1 times.
[00005] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.106.73:8224 to xxx.xxx.xxx.xx3:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
[00006] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.106.73:31589 to xxx.xxx.xxx.xx3:1029, proto UDP (zone Untrust, int untrust). Occurred 1 times.
[00007] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.103.49:8224 to xxx.xxx.xxx.xx6:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
[00008] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.103.49:17674 to xxx.xxx.xxx.xx6:1029, proto UDP (zone Untrust, int untrust). Occurred 1 times.
[00009] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.94.151:8224 to xxx.xxx.xxx.xx2:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
[00010] 2004-03-17 12:01:38 [Root]system-critical-00429: Fragmented traffic! From 66.90.94.151:5950 to xxx.xxx.xxx.xx2:1029, proto UDP (zone Untrust, int untrust). Occurred 1 times.
[00011] 2004-03-17 12:01:37 [Root]system-critical-00429: Fragmented traffic! From 66.90.96.227:8224 to xxx.xxx.xxx.xx2:8224, proto UDP (zone Untrust, int untrust). Occurred 2 times.
1 REPLY
Re: Fragmented traffic alarms
Hi all
http://www.dshield.org/port_report.php?port=8224
http://www.dshield.org/port_report.php?port=1029
Simon
