Flash Scrollbars disapear on website
I have done a flash website which works perfect on my pc but when I upload it the scrollbars disapear and wont work.
http://www.blocksealer.co.uk/flash/index2.htm
If I download the file from the site back to my hd the scrollbars still wont work so somwere along the line it gets corrupt. I have tried uploading with different ftps and to different plus nets sites and it all the same.
Its all done in Flash 2004 pro and the scrollbars are the ones provided with flash
Anyone any ideas?
Cloudmaster
If I go to your link I just get a white space where the scroll bar should be, if I go to http://www.acc-sol.co.uk/index2.htm I get the scroll bar, but it doesn't scroll (presumably because there's not enough content)
Yes that is the problem there is a scroll bar there but it disapears and looks like a white line but why.
The other page is done differant if you click on the arrows it scrolls. I had to do this as the scrollbar was disapearing.
I cant understand why its ok on my home pc but not on the website
