First support request
Have just set up and configured X-Lite.
However i am getting a login failure - contact network admin.
I think I have configured my firewall correctly. Skype works but having issue here.
Logs below........ x = content removed
© 2004 Xten Networks, Inc. All rights reserved.
X-Lite release 1103m build stamp 14262
License key: A20F7A4470AC4A68872792C03D9D9405
Established SIP protocol listen on: 192.168.0.2:5060
Discovered Port Restricted Cone NAT Firewall
SIP: 192.168.0.2:5060
RTP: 192.168.0.2:8000
NAT: 84.92.105.129
PROXY#0: 212.159.6.146:5060
PROXY#0: 212.159.6.145:5060
PROXY#0: 212.159.6.161:5060
PROXY#0: 212.159.6.162:5060
SEND TIME: 317508875
SEND >> 212.159.6.161:5060
REGISTER sip:embarkell.plus.com SIP/2.0
Via: SIP/2.0/UDP 84.92.105.129:5060;rport;branch=z9hG4bK5BD09965E1754E109D8A24DCCDAE30ED
From: xxxxxxxx<sip:plustalk@embarkell.plus.com>;tag=1337594885
To: xxxxxxxxx<sip:plustalk@embarkell.plus.com>
Contact: "xxxxxxxxx" <sip:plustalk@84.92.105.129:5060>
Call-ID: 977ED56503D84ACD8C107327C2B71E49@embarkell.plus.com
CSeq: 63857 REGISTER
Expires: 1800
Max-Forwards: 70
User-Agent: X-Lite release 1103m
Content-Length: 0
RECEIVE TIME: 317508968
RECEIVE << 212.159.6.161:5060
Via: SIP/2.0/UDP 212.159.6.161;branch=z9hG4bKc51.31e98cd4.0
Via: SIP/2.0/UDP 84.92.105.129:5060;rport=5060;branch=z9hG4bK5BD09965E1754E109D8A24DCCDAE30ED
From: xxxxxxxxx<sip:plustalk@embarkell.plus.com>;tag=1337594885
Contact: "xxxxxxxx" <sip:plustalk@84.92.105.129:5060>
Expires: 1800
Max-Forwards: 16
Content-Length: 0
SEND TIME: 317508968
SIP/2.0 405 Method Not Allowed
To: xxxxxxxxx<sip:plustalk@embarkell.plus.com>;tag=1337594885
Contact: <sip:plustalk@84.92.105.129:5060>
Allow: INVITE,ACK,BYE,CANCEL,OPTIONS,NOTIFY
Server: X-Lite release 1103m
Content-Length: 0
RECEIVE TIME: 317509031
To: xxxxxxxxxxx<sip:plustalk@embarkell.plus.com>;tag=1337594885
Content-Length: 0
SEND TIME: 317529093
SEND >> 84.92.105.129:5060
REGISTER sip:84.92.105.129:5060 SIP/2.0
Via: SIP/2.0/UDP 84.92.105.129:5060;rport;branch=z9hG4bKAA48788E498241F480A115D9D82D7253
CSeq: 63858 REGISTER
Expires: 1800
Max-Forwards: 70
Content-Length: 0
Any ideas?
csogilvie
I'm fairly sure that the server shouldn't be sending you a REGISTER message back again, which is what it seems to be doing... quite what you can do about it, I'm not sure though Sad
Working now Colin.
Whatever they did seemed to correct it.
Thanks.
