Firefox
Firefox
In my home computing history, I've used most of the Microsoft operating systems, only briefly becoming aquainted with V3.1, then moving to W95 (as it was free with my old Pentium 75 ughh!!) through 98, 98SE, Me, 2000 and finally XP home.
At the start of dabbling with the internet, to the derision of my computer using family and friends, I used and stayed with a web browser called Netscape for a quite long time, while the rest of the world moved on to the various versions of IE, and never having any real trouble with it (I still have one of those Netscape mugs with a rubber base) I only have a vague recollection of the Netscape version numbers, but I think the last I used was V5.5, but maybe wrong, before joining the throng with IE.
In the latter stages, I recall that Netscape had a bit of a re-name that included Mozilla...is the current Firefox OS a direct decendent of Netscape?
Rich
Firefox
That's right. Firefox was developed after Netscape released the source code under an open source license. See here for more details...
http://computer.howstuffworks.com/firefox5.htm
Firefox
Yes, thanks for that, there are times when I wish I'd stayed with Netscape, indeed there are times when I think staying with Win2000SE would have been an even better idea...but too late now.
lingbob
Firefox
Netscape is still available, I think it's at version 8 now.
I looked at it a while ago and it now has the choice of using either the Firefox or the IE rendering engine.
Perhaps you should have a look Smiley
Martin
Firefox
Thanks Bitzbox, but having changed to Firefox (see Malicious Spyware posting) I think I'll stay where I am now ta! I've stripped IE back to it's bare essentials (no toolbars, history or favorites etc.) and set Windows Update as the home page, as it's still necessary to get them.
