FXO on a SpeedTouch 780
Has anyone managed to get a SpeedTouch 780WL to get direct access to PSTN?
I look after another location which has a SpeedTouch 716WL and you just hit "9" to get to the PSTN line. That doesn't seem to work with the 780 and neither does the *01* code that the manual says should work.
TIA - MarkW
I have a Speedtouch 716, and I had to add the FXO facilty using the CLI interface. Open a dos box and telnet speedtouch.lan, username Administrator and password (whatever your password is). Then you can provision forced FXO
Hi, I have no problem with the 716, it just works. the 780 on the otherhand is a right pain (I'm wondering if it is faulty). I can get the forcedFXO both provisioned and activated using the CLI, but it makes no difference. I don't even get a line when the 780 is turned off which makes me think maybe there is a hardware fault.
