FTP Server
FTP Server
Hi is it possible for to setup an FTP server on my PC if im behind a router and i have a static ip from plus.net. If so can you help me out? also is it possible for me to host a Teamspeak Server now i have static ip?
thank you
FTP Server
This is possible using port forwarding in your router and using an FTP server like serv-u.
FTP Server
You will need to forward TCP 20 and TCP 21 (data and connection ports)
Teamspeak uses diff ones , use google to find out which.
Use www.guildftp.com (guildftpd) as ur FTP server as its free and great Wink
Buz
FTP Server
Ok i have already forward these port on my router but when i try to setup my ftp server using serv-u it wont go online and teamspeaks IP is my local IP and i cant get my static IP on there Sad anyone know why
FTP Server
dont use servu
FTP Server
oK does bullet proof work ok?
FTP Server
www.guildftpd.com <--- get the hint and use it :p its the best FTPd out there *that is free and isnt for linux (glftpd)
PF sucks so bad on so many levels its untrue.
Buz
FTP Server
BlackMoon FTP Server rocks!
FTP Server
hmm ok i tryed them both! i think my ip has been hijacked!!
