Eyebeam v1.5
LokisRainbow
Eyebeam v1.5
I've just upgraded to Counterpath's new version of the Eyebeam softphone, and am having trouble with the configuration settings. It was quite easy to manually configure v1.1 (with a little help from previous posts on this forum Cheesy ) however in v.1.5 most of the configuration is done automatically.
Has anyone else tried the Eyebeam v1.5? If so, how can it be configured to work the PN Plustalk?
I'd be grateful for any suggestions.
Thanks,
Shan
monty
Eyebeam v1.5
Would you mind posting the setting for version 1.1 as I cannot get it to work .... Shockedops: Shockedops:
LokisRainbow
Eyebeam 1.1
Hi, these are the settings I used for version 1.1 Hope these work for you. Smiley
Display name - Anything you like
User Name - plustalk
Password - your plus net portal password
Auth User name - plustalk
Domain is - YOURUSERDOMAIN.plus.com ( username.plus.com email address)
Register with Domain - ticked.
Make sure use as "outbound proxy" is Un-checked
SIP listen port is left blank no tick etc.
If it still doesn't work, you will need to the "System" section, then Network.
Un-check auto detect IP address, and enter your static IP.
