Endian Firewall
madswitcher
Endian Firewall
Hi All,
I thought I would drop everyone a line to let them know about the Endian firewall project.
If you have a spare machine with a couple of NICs and capable of running Linux, then I highly recommend that you look at using this software to build a firewall appliance. Even at the beta stage, it is still a formidable product
look at www.efw.it to download the iso image - its free at the moment
Regards, Mike
Endian Firewall
Thanks for the mention Mike,
Looks pretty good Smiley
holdtight
Endian Firewall
Its along the same lines as smoothwall and ipcop Mike which ive run on and off through several versions over the past few years
If you have a spare machine its a great way to put together an easy to use and configure hardware firewall which is pretty much impenetrable
cheers for the link i might give this one a go to see how it differs from the others and if its any better
Bill.
madswitcher
Endian Firewall
Holdtight
Yes I used ipcop for some time (and thought it was great) and then saw this which has a lot more features in it so I gave it a go.
It is, in fact, based on ipcop. The IDS and Content chacker are quite good and the proxy-cache does give a significant boost when you have several users like we have.
Cheers,
Mike
holdtight
Endian Firewall
Thanks for the info Mike ill give it a go when ive got some time sounds like it might be a good one
Cheers
Bill.
