Email Links Help
Email Links Help
I was on AOl and have changed to Plusnet.Great move on my part.
On Email after uninstaling AOL when i click on a link in my Email it does not respond.Could someone tell me how to fix this please
Email Links Help
First of all we need to know just what you are using as your email client.
i.e outlook express, outlook etc?Huh
Email Links Help
From your other post it looks as though your smtp settings may not be correct.
As John says, more info on what mail client you are using and the way you have it configured would help.
Email Links Help
I'm using Outlook Express
Email Links Help
How have you configured your outgoing (smtp) settings?
it should be relay.plus.net.
Email Links Help
Just to elaborate on the above.
For Outlook Express go to Tools then Accounts and click on Add and then Mail.
Follow the wizard and use mail.plus.net for ithe incoming POP3 and relay.plus.net for the outgoing smpt settings.
Use your username and password for the account details requested and thats it.
Email Links Help
SMTP settings are OK
Pete
Email Links Help
There is a tutorial under the help section on the portal.
For outlook Express the specific information can be found here
