Dreamweaver FTP Failing
When I try to upload my site using dreamweaver I'm getting the following error message.
An ftp error occured cannot put index.htm Access denied
My settings are as follows:
ftp host ftp.plus.net
I get the error when I use htdocs or not as initial directory?Huh
Can you upload other files? If you can its a permisions thing on the file. If you cant then its wrong username/password or bad connection
Access: FTP
FTP Host: ftp.plus.net or ftp2.plus.net or www.username.plus.com
host directory: htdocs/
login: yor usual login name
password: your usual portal password
Try with and without 'use passive FTP' ticked.
Click the test button to confirm you entered the correct login/password and FTP server details. Until this works, you won't be able to upload any files.
Host directory must be at least htdocs/ because you can't write files to the same directory level as htdocs, only within htdocs or a directory you create within htdocs.
If you have a firewall enabled, disable it temporarily to see if that is causing your connection problem. Blocking by your local firewall is by far the most common reason for FTP connections to fail. If it works with the firewall disabled you know where to look for the solution. Also disable any anti-virus software for the same reasons.
Disabling my firewall worked, many thanks for the help.
