Download Scheduler
home99
Download Scheduler
Hi folks,
Just discovered Azureus and bit torrent so I was wondering can I schedule the program to start downloads at night - fire and forget so to speak. I suppose I am looking for a third party piece of software.
Appreciate any comments
Regards
Dave
Alecto
Download Scheduler
There's a scheduler plugin for Azureus that will do it.
Go via the Plugins tab to download it.
home99
Download Scheduler
Sorry I should have checked Shockedops:
Appreciate the reply though Cheesy
Regards
Dave
home99
Download Scheduler
Hmmm, I can only find a speed scheduler which I am assuming is not the plug in I want. There is a link to 'triggermenuitem' which appears to be the sort of thing I am looking for.
However - I have read it and read it and I don't understand it.
Is there a lay persons version?
Regards
Dave
Download Scheduler
The plugin you requre is called Speed Scheduler, I am using it myself. Just tick the plugin, continue forward until you ht finish and it should be downloaded automatically and installed. You then just restart AZ and configure it via the Plugins menu.
No idea what you mean by 'triggermenuitem'
home99
Download Scheduler
Yep got it now - apologies I misread speed scheduler as a plug in to vary the speed of your connection only and not to start and stop downloads.
Cheers Peter
Regards
Dave
Grff
Download Scheduler
or you could set a windows scheduled task to open azureus up for you at a particular time.
