Domain Name wont load my web site
I'm not an expert, but I think that the domain setting should just point to a folder, rather than a specific document.
Perhaps somebody who knows a bit more about this could enlighten both of us?
Hello
I've setup the £1 Domain name to point to my website - yesterday all was fine, and www.nicholaskingsley.co.uk was loading everything okay. Unfortunately today, for some reason, all its doing is say :
Not Found
The requested URL / was not found on this server.
The domain setting is pointing to /htdocs/index.html (which is correct and present). I also get the "Not Found" on other computers too.
How can this be fixed ?
Have tried it with the default folder, but no luck - unless, it takes 24 hours to update...
Your suspicion is correct - had a scan though the associated help files, and came up with
You should notice that there is usually a 24-48 hour take-up period before the DNS is changed and this information starts to propagate across the Internet
To read the full document click here
I'll leave it for 48 hours or so, and see if its availiable after that...
Yes, its fine now Cheesy
