Domain Files
Domain Files
I wondered if it is possible instead of having www.username.plus.com/index.html if its possible having it www.mydomain.co.uk/index.html?
Craig
1 REPLY
Domain Files
Why do you want to tag the index file nname onto the end of the URL?
The whole idea of the index file is that when someone calls your spce it opens automatically with just www.domainname.co.uk
If its because you want to keep your domain seperate from your own files then just put it in a folder and use the domain names tool to have it point to that folder.
