Domain Email Woes
Domain Email Woes
I'm having no luck getting my domain email delivered to me SMTP server.
I can send outbound email, receive inbound from my Plus username email via POP3, I can even telnet to my SMTP server from outside. But anything sent to my domain address gets bounced with the following error:
>This message was created automatically by mail delivery software.
>A message that you sent could not be delivered to one or more of its >recipients. This is a permanent error. The following address(es) failed:
> simon@xxx.co.uk
> Too many "Received" headers - suspected mail loop
I've read the "how to" guides and several posts in the forums, but I'm still not having any luck.
My mail settings in the portal are set to "other" and the DNS entries look like this:
LEFT TYPE PRI Right
www a 81.174.xxx.xxx
beaker a 81.174.xxx.xxx
mx 5 beaker
"beaker" is the name of the mailserver
Any help would be gratefully received.
Cheers,
Q.
[/img]
Domain Email Woes
How long ago did you activate Other or SMTP delivery?
I beleive this can happen whilst internal DNS records timeout.
Domain Email Woes
It's now about 24 hours since I made the change. The non delivery errors have stopped, but the mail still isn't getting through to my server.
Even email from my me@accountname.plus.com isn't arriving at my server (I'm assuming the Plus DNS would have updated by now).
I'm still wondering if the DNS records are correct?
Domain Email Woes
So, are the DNS records set up correctly, anyone.....?
Mail still isn't arriving.
Domain Email Woes
The mail is still not arriving and the contents of the NDRs has now changed:
>A message that you sent has not yet been delivered to one or more of its
>recipients after more than 24 hours on the queue on pih-mxlast01.plus.net.
>The message identifier is: 1DMMmA-00031G-Rj
>The subject of the message is: test
>The date of the message is: Fri, 15 Apr 2005 10:16:10 +0100
>The address to which the message has not yet been delivered is:
>simon@blahblah.co.uk
>Delay reason: Connection timed out
>No action is required on your part. Delivery attempts will continue for
>some time, and this warning may be repeated at intervals if the message
>remains undelivered. Eventually the mail delivery software will give up,
>and when that happens, the message will be returned to you.
Domain Email Woes
Thanks for all the helpful suggestions.
You'll no doubt be pleased to hear the problem is now resolved.
