Difficulty re-opening X-Lite
fotobits
After closing down X-Lite, I find I cannot open the program again in the same Windows session.
Any ideas?
Ought I to re-install?
Regards and thanks.......
Re: Difficulty re-opening X-Lite
Any ideas?
    When you close X-Lite it minimises to your task bar (near the clock).
    If you right click on the icon and exit the program opening it up only brings the icon back.
    You need to double left click the icon to open up the softphone window.
fotobits
Many thanks.......
