Dialing plustalk from asterisk fails
I'm trying to get Asterisk to dial out through PlusTalk. It's registered with the peer ok:
rivendell*CLI> sip show registry
Host Username Refresh State
sip.plus.net:5060 plustalk@riv 105 Registered
But when I try and dial I get a "bad request":
-- Executing Dial("SIP/rivendell-5704", "sip/sip.plus.net/01159xxxxxx") in new stack
-- Called sip.plus.net/01159xxxxxx
-- Got SIP response 400 "Bad Request" back from 84.92.5.190
-- SIP/sip.plus.net-8ba4 is circuit-busy
I'm not sure where to go from here since "bad request" doesn't do much to tell me what's wrong.
Hi, can you tell me what you have in your sip.conf - it might help to shed a bit more light on the problem.
register => plustalk@rivendell2.plus.com:xxxxxxxx@sip.plus.net/plustalk
[sip.plus.net]
dtmf=rfc2833
type=friend
username = plustalk@rivendell2.plus.com
fromuser = plustalk
secret = xxxxxxxx
fromdomain = rivendell2.plus.net
host = sip.plus.net
context = default
insecure = very
qualify = yes
canreinvite = no
allow = all
Doh! spot the bug Smiley (should be .com, not .net)
Did you manage to get it going after that correction? Using your settings, I get as far as attempting an outgoing call connection which rings but the call does not complete.
Yep, it works... or rather, it gives me a recorded message saying I'm out of credit but I'm currently giving PN support a kick about that since I'm supposed to have 240 free minutes...
I have sorted out outgoing calls but incoming are not yet reaching me. Its needs some more work.
If you want to test out your system further, try dialling **393411 which takes you via the FWD peer link to where they have a voice interactive news/current affairs line that is free to use.
