Dial up number for use with ADSL
I have teleworker lite broadband for home use but would like to just check e-mails from my mobile phone hooked up to my lap top. Can you provide the a local rate number I should dial up ?
Paul
Moderators note by John (johnessex) Post split from the end of a thread in the Tutorials section.
Denzil
I believe there is a pay as you go dialup number that can be used as a backup in case ADSL fails. I suggest you call the helpline (0845 1400200), they will be able to tell you the number.
I don't know about Teleworker Lite, it's probably a different number to the one I have for Home PAYG (0845 1400101), but if you click Connection Settings in the links at the left-hand side of this forum, then click Connection Details, it should tell you.
