Designing Cascading menus in Frontpage
Fixes: 142
Hi.
I can't find any help here or within FP:-(
Basically I want to design a menu such that the top-level item has a plus to the left side as in a normal Windows display. Clicking on that or the item itself displayes a list below it and slightly to the right with the remaining menu items shifting downwards.
Clicking onthe top-level item again closes the items and the lower ones shift back up again.
Hope I have explained it properly.
Any help greatly appreciated.
Cheers
Forum Moderator and Customer
There's a few javascripts that might do this.
Take a look at javascript.internet.com theyv'e got loads of useful scripts.
Chris
the place to be is
http://www.apycom.com/apmenu/lg.html
Dreamweaver or fireworks does what you want but FP is not very good, th enew FP 2003 has it built in but its not very easy
