Dead Number
Dead Number
Hi All
Has anyone had any problems getting the 0845 numbers to bind to this service, I have no problems with outgoing connections, but any Inbound and I get number not available dial tone.
Using X-lite nated with xp firewall on local machine (ports enabled)
Cheers
Dead Number
I get this problem too with my 0845 number, when I try to call it from a landline, there's no ring tone after I dial the number Sad
Has anyone else had this problem...or know why it happens?
Thanks,
Luke
0845 number problem and Plustalk voicemail
My 0845 number binds OK but half the time the call goes to Plustalk voicemail rather than being delivered to my Asterisk box. This behaviour seems to be totally random with the calls being delivered to Asterisk properly for hours then mysteriously going to Plustalk voicemail for hours. Rebooting my Asterisk box and thereby causing it to re-register with the Plustalk SIP server does not remedy the problem.
Does anyone know how I could cease the unwanted Plustalk voicemail?
monty
Dead Number
I have the same problem my 0845 just give a dead tone when you try to call it, am I supposed to put it into x lite somewhere ?
Dead Number
Yeah mines is totally dead as well... a bit of a bummer
any ideas?
Dead Number
Since I last posted I've contacted PlusNet support, and after doing some internal tests, they've come to the conclusion that there is actually a problem, and that's it's not just my PC setup :roll:
At the moment, my support case is still being delt with. With let you know if they get round to fixing it.
Regards,
Luke
