DUALphone on PlusTalk
Anybody had luck getting the LAN version of DUALphone working on PlusTalk, the product I mean is here.
If I put the device into a DMZ then it works ... well I can get incoming calls, but no outgoing ones! If I take it out of the DMZ and forward the usual SIP/RTP ports, nothing works.
I need it out of the DMZ as my PS2 needs to be in the DMZ.
Thoughts?
SW.
3Mb FTTC
