DSO Exploit & Spybot ?
joecool
Hi one entry of a 'DSO EXPL0IT' shows up each time after it is fixed in 'SpyBot'?
I have all the updates & patches !
Is this a problem with 'spyBot' ?
Appreciate any help
Thx !!
Yes it is a known problem with Spybot.
Just add the exploit to the ignore list.
See Hacked again for info on removing it (and you should remove it not hide it as suggested above).
joecool
Will check out .......Thx Smiley
