DNS problems
DNS problems
This is slightly difficult one to explain. However, I'll do my best,
hoping you can come up with an answer for me.
I'm putting together a hosting company on the web, out of 4 partners,
I am the only one not able to get http://www.oneworldyours.com up on IE or any
of the subdomains we have installed. I've search the web for answers but
cannot find what I need to know. However, I can get the IP and the 'named'
cpanel, it being http://oneworldyours.com etc .......If I then type in
http://www.oneworldyours.com, I get a DNS page come up, that includes all the sub-domains.
I have XP and IE updated. Does this mean there is a problem with my
OS or DNS setting on my computer? I'm not sure where else to look, I'm
totally stumped.
Having checked my computer with ipconfig /all everything looks fine. However, someone suggested I ask the following ....
If they belong to your ISP, you should contact them to find out why their DNS servers are not reporting the correct A record for www.oneworldyours.com.
I would appreciate any help you are able to give me.
Regards
Cass
DNS problems
I can access www.oneworldyours.com fine with both IE and Mozilla.
What DNS servers are you using?
In a DOS box, try running nslookup www.oneworldyours.com and see what it returns, also post ping and tracert results. I get the following:
C:>nslookup www.oneworldyours.com
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
Non-authoritative answer:
Address: 67.18.160.132
Aliases: www.oneworldyours.com
C:>ping www.oneworldyours.com
Pinging oneworldyours.com [67.18.160.132] with 32 bytes of data:
Reply from 67.18.160.132: bytes=32 time=121ms TTL=49
Reply from 67.18.160.132: bytes=32 time=120ms TTL=49
Reply from 67.18.160.132: bytes=32 time=119ms TTL=49
Ping statistics for 67.18.160.132:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 119ms, Maximum = 121ms, Average = 120ms
C:>tracert www.oneworldyours.com
Tracing route to oneworldyours.com [67.18.160.132]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 14 ms 15 ms 15 ms lo1.homesurf.pth-ag1.plus.net [195.166.128.32]
3 16 ms 16 ms 16 ms gi1-2.vlan16.pth-gw3.plus.net [212.159.1.244]
4 16 ms 16 ms 15 ms ge-4-1.metro1-londencyh00.London1.Level3.net [212.113.11.33]
5 17 ms 17 ms 16 ms so-1-2-0.gar1.London1.Level3.net [212.113.0.114]
6 17 ms 16 ms 16 ms so-7-0-0.mp1.London1.Level3.net [212.113.3.1]
7 17 ms 15 ms 16 ms so-3-0-0.mp1.London2.Level3.net [212.187.128.46]
8 87 ms 88 ms 89 ms as-0-0.bbr2.Washington1.Level3.net [4.68.128.102]
9 121 ms 122 ms 125 ms so-0-0-0.bbr2.Dallas1.Level3.net [64.159.0.137]
10 123 ms 121 ms 120 ms so-7-0-0.edge1.Dallas1.Level3.net [209.244.15.166]
11 125 ms 122 ms 121 ms unknown.Level3.net [63.209.48.110]
12 121 ms 122 ms 122 ms dsr2-1-v1.dllstx4.theplanet.com [12.96.160.7]
13 122 ms 121 ms 123 ms gig1-0-1.sm-car6-3.dllstx4.theplanet.com [67.18.116.99]
14 121 ms 125 ms 122 ms server27.integrityserver.net [67.18.160.132]
Trace complete.
C:>
DNS problems
I have done all that via www.dnsreport.com I can get it from their site, however, I cannot get it from my computer .........
When I pinged, this is the information ......
Ping request could not find the host www.oneworldyours.com. Please check
the name and try again ....... however, if I use the IP it pings.
DNS problems
I'll ask again, what DNS servers are you using, the ipconfig /all will usually tell you this (unless you are pointing it at your router). Also try the nslookup command as I suggested and post the results.
DNS problems
The following results ......
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Cass>nslookup
DNS request timed out.
timeout was 2 seconds.
*** Can't find server name for address 212.159.13.49: Timed out
Default Server: pth-cdns02.plus.net
Address: 212.159.13.50
regards
Cass
DNS problems
Also try ipconfig /flushdns to clear out any dead DNS entries that Windows may have cached - or just reboot your PC and try again.
What ADSL hardware are you using? If an external router, try a power cycle on it and try again.
DNS problems
C:\Documents and Settings\Cass>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
I'm using Binatone ADSL 2000
Thanks for your help, Peter, it really is appreciated.
regards
Cass
DNS problems
All 6 PlusNet DNS servers are responding well so this must be a local problem somewhere.
Still don't know what DNS servers you have configured - what did ipconfig /all say they were?
Also in your router, did you manually set the PlusNet DNS servers or did you let the router get them from PlusNet automatically?
DNS problems
Sorry, I missed the one your asked for, but here it is ....
C:\Documents and Settings\Cass>ipconfig /all
Host Name . . . . . . . . . . . . : cass
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Unknown
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Binatone ADSL 2000 Ethernet-USB Rout
er
Physical Address. . . . . . . . . : 00-0A-E2-10-11-06
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.4
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.2
DHCP Server . . . . . . . . . . . : 192.168.1.2
DNS Servers . . . . . . . . . . . : 212.159.13.49
212.159.13.50
Lease Obtained. . . . . . . . . . : 07 July 2004 20:29:04
Lease Expires . . . . . . . . . . : 19 January 2038 04:14:07
I allowed the router to auto configure.
Regards,
Cass
DNS problems
Everthing looks fine there.
So, did powering the router off and on make any difference? I assume by the lease date above you have rebooted your PC recently.
DNS problems
None whatsoever, Peter.
I'm beginning to pull my hair out.
Regards
Cass
DNS problems
Are you running a software firewall or have the windows firewall enabled? If either (or both) try disabling them and try the nslookup again. Also say what firewall you are using.
A lomg shot but try disabling any anti-virus software as well.
For some reason your PC cannot contact the .49 DNS server.
DNS problems
Peter,
I stopped running firewalls, external from the router, my anti-virus was Norton, but their updates were causing system problems. So I now use AVG, I have actually disabled it to see if that was a problem. Nothing has changed, unfortunately.
Could it be the router?
regards,
Cass
DNS problems
Peter,
If I can't see .49 DNS, then should I make .50 and then 212.159.6.9 primary and secondary?
Regards,
Cass
DNS problems
Do you know how to set the DNS IP addresses manually in Windows? If so change them to 212.159.6.9 & 212.159.6.10
If not start->control panel->network connections. Right click on your network connection and select properties. Then select TCP/Ip and click properties.
Select ;Use the following DNS addreses and enter the 2 IP addreses above, then click OK and OK. Right click the network device again and disable it. Repeat this and enable it again.
Then try the nslookup command again.
