DNS issue?
DNS issue?
For some reason i cannot reach (by browser):
http://www.comptechdoc.org/os/linux/commands/linux_crfilest.html
or its address of:
http://209.197.236.44/
A tracert shows OKHuh
DNS issue?
If you can do a trace route and cant connect via an ip its not a dns issue. You only get dns issues if you try by name and it cant find it. If you use the ip you dont use dns.
You dont say which browser I assume IE. Try clearing all the cache in IE and see if that cures it. What error do you get?
DNS issue?
It appears the IP address is hosting several domains which is why i get the blank page.....
I was using my Ubuntu box last night when i couldn't view it but on another machine now and it works....
I'll clear the cache in the browser and go from there. Thanks for your reply.
