DNS Suffix
DNS Suffix
I am setting up me Exchange 2003 server to use Blacklists to stop the spam and virus emails reaching my users mail boxes.
I order to do this I need the DNS suffix that Plus Net appends to the IP address.
Does anyone know what it is? :roll:
Cheers for any help,
Roddy
DNS Suffix
That should be obtainable via ipconfig on the command line, provided you are using DHCP and the the router doesn't eat the value.
mssystems
DNS Suffix
If I have this right you want the public domain name that plus return in response to an rdns request. IPConfig will only give you the internal domain name which is probably different.
The rdns is usually username.plus.net
You can check your rdns by running a trace from outside your network. If you have a look at www.visualroute.com on the live demo page you can run a trace from various servers around the world. Enter your public IP address and your rdns name will appear in the node name column
HTH
Matt
DNS Suffix
Thanks Matt, I've tried the Visual Route demo and I've entered the Suffix so hopefull that will do. Thanks for your suggestion Phil but the ipconfig command will only tell me the internal IP range as the router and firewall block everything under the sun (except spam!).
Cheers for your help.
csogilvie
DNS Suffix
The rDNS is actually usually username.plus.com (as thats the default)
DNS Suffix
If you computer gains the IP from a DHCP server, than the following should normaly be sent
IP
Subnet mask
Default gateway
DNS servers
hostname
DNS suffix
Not all DHCP servers give the suffix out. IE, My Zyxel doesnt, but my SAR715PV and EN5861 do.
