DNS MX Records
mssystems
DNS MX Records
I want the MX records in my plus hosted domain to point to a mail relay outside of Plus which is providing AV and spam filtering
Using the Plus Configure DNS control panel, is it legal to have a blank left field and a FQDN host name in the right field.
e.g.
left, type, pri, right
,MX,10,mail1.avfilter.net
,MX,20,mail2.avfilter.net
I seem to recall that you can end up with your own domain name appended if you get this wrong.
Help appreciated
DNS MX Records
Not sure about the left field but put a trailing dot on to the right field Wink
(Without the trailing dot the name isn't terminated and so you might get plus.com etc appended...)
mssystems
DNS MX Records
Ahh. I always forget that bit thanks.
The blank left field seems to have worked.
DNS MX Records
Wink So do I normaly... I can spot it when others forget it but cant spot it when I do...
