Cutting out my voice
Hmm.... well when i call the echo test, i can only hear the echo if i speak really loud, even then it cuts the first bit off. Is this just with the echo test or is it for all calls? I think it could be todo with the noice reduction function. Is there anyway to turn this off?
1 REPLY
ah i beleive i have found the option to turn this off. w00t.
