Creating a multimap / streetmap style website
Hello All,
I am currently looking into creating a Multimap - www.multimap.com map interface on a website.
What do you guys think would be the best way of setting it up?
I have (or rather can get) the source maps as a series of GIF tiles at various different zoom levels.
My ideas so far have been to have a MySQL database of all the different tiles, then use PHP to grab the requested tile depending on the selection criteria (zoom level, co-ordinates, etc).
In addition I would need some image map which would link into these co-ordinates and zoom level thingy.
I know its a helishly complicated project (considering the amount of data and coding time needed to make it work), and something of a size which I have never attempted before.
If anyone has any suggestions, or comments about my current ideas, if MySQL / PHP is the best solution? etc etc I would be interested to hear them!
Cheers
Tom
PS the maps are of Belgium - in particularly Brussels.
Sorry a side point, rather than an answer to your question.
You can use correctly formatted URL’s to point to maps on www.multimap.com
The URL is made up of; (On a single line.)
http://www.multimap.com/map/browse.cgi
?client=light
&GridE=-1.3774
&GridN=52.3657
&lon=-1.3774
&lat=52.3657
&db=hcgaz
&scale=50000
&client=light
Examples;
http://www.multimap.com/map/browse.cgi?client=light&GridE=-1.5561&GridN=52.2729&lon=-1.5561&lat=52.2...
http://chillypenguin.plus.com/wwwd/chilly.htm
Chilly
I think we might be going with Multimap.
They charge £1500 per year plus 2.4p per map access, although this seems *way* too steep.
The other option is to get proper GIS data and a custom built interface from someone like www.lovelljohns.com at a cost of £10k
Or shall I build it ,myself?
Decisions, decisions.
