Connection speed on plus
Plusnet Staff
Plusnet Staff
Yep, the BT Speedtest can be a little temperamental. Generally seems to work best during off peak hours because less people are using it. Also seems (to me at least) prefer Internet Explorer.
HI, i'm on Plus up to 8Mb. When i do a speed test using my upspeed is 363.43Kbps and Downspeed is 501.25 Kbps. I know the speed is supposed to be area dependent, however this is the same speed my connection had over 2 years ago when the plus account had a 512Kbps connection. I would have thought technology would have done something by now to increase the connection speed!!!
Any ideas please?
Liam
Judging by your upspeed, it looks like you've been moved to an "Upto 8Mb" connection.
Could you give this a whirl : http://speedtester.bt.com ?
kenny
I`ve tried to do this test but when it asks for log in name its no good?
I`ve tried my email address, password etc no good? what do I put in to finish the test
Fixes: 46
First the phone number for the line, then the login name which you use for your broadband connection. This will be <whatever>@f9.co.uk
Patience is needed, it can take a minute or two to work through the test.
David
David
