Connecting with PocketPC
Has anyone any experience of connecting to Plus with a PDA. Specifically a Jornada 567 running PC 2002, to the 0845 dial up?
It appears to dial correctly and connect but immediately disconnects with a message advising me to check username & password. I've used the connection wizard, and tried setting the connection manually. I'm using the same settings as with Windows ME on the PC which connects OK.
Help!
David Marsden
1 REPLY
error message
i think you have to call your mobile company and get "data" enabled on your mobile sim card.
