Connecting ADSL
Connecting ADSL
I recently moved house and I understand that there is a £65 cost involved in having ADSL connected at the new property, does anyone know of a cheaper way of doing this, BT direct? anything would help I only plan to be in the property for 6 months.
1 REPLY
Connecting ADSL
There is no cheaper way.
The 65 pounds is the fee that BT charge PlusNet for the work on connecting your line.
If you are only going to be there for 6 months then you need to go for a monthly contract which is more expensive but allows you to just give the 30 days cancellation notice.
