Confused
Confused
In the 'Member centre' >>>>>>>> 'My Account' >>>>>>>>> 'Account Details' >>>>>>>>>>> 'Plus Talk' >>>>>>>>>>>>> 'Tarif' Tab, it says that National calls are Daytime 1.5p, Evenings 1.0p, Weekends 1.0p
But when i signed up i signed up for anytime and was under the beleif that all 01/02 numbers were free.
HuhHuhHuhHuhHuhHuhHuhHuhHuh?
LiamM
Confused
If you signed up for Anytime, then these will apply if you go over 3,000 minutes per month. And let's face it - this isn't likely.
They are also applicable for those customers who are on PAYG, or Eves and Weekends.
Confused
Where does it say that then? Shockedops:
Confused
7. Is there a call time limit?
To ensure that calls are not left accidentally connected there is a maximum call time of 59 minutes and 59 seconds. You can re-start the call again at anytime after being disconnected.
http://portal.plus.net/support/plustalk/plustalk_faqs/plustalk_using_faq.shtml#link_7
it doesn't. Infact it doesn't tell you anything about the 'Anytime' Plustalk until after you start the signup process. http://portal.plus.net/residential/voice/plustalk_spec.shtml
The included minutes are for the business customers on the business contract.
Business
PlusTalk Business: 3000 inclusive minutes per month to UK landline numbers beginning with 01 & 02 at anytime.
PlusTalk Business Extra: 5000 inclusive minutes per month to UK landline numbers beginning with 01 & 02 at anytime.
Confused
i have only ever seen the 2000 min / month info once in the registration procedure...never found it since sign up, very confusing?
Confused
I have had another look...where does it actually state the inclusive min allocation for Anytime non-business customers? This all seems a bit 'cloak and dagger'!
Confused
You're quite right - i remember seeing it on one of those links that druidswand posted and now it's gone altogether.
Maybe it's subject to SUP/FUP? :shock: :shock:
prichardson
Confused
These details are available in the PlusTalk FAQ [HERE], as linked to in the Terms & Conditions.
Kind Regards,
Confused
Ah - cheers for that Phil
Wish zyxel would hurry up with my replacement 2002L Sad
Confused
Kind Regards,
Which you only see after the 'sign up process', nothing is linked to that untill after the customer has decided to buy.
