Configure Cisco 7940 with PlusTalk
Has anyone successfully configured a Cisco 7940G for PlusTalk ?
What detail goes into which option on the phone ?
I've tried all the logical options to no avail, had no problems setting up with other providers...
Might be an idea for a sticky so that a matrix can be built up to help quick configuration of different phone models :?:
Figured it out .....
Finally figured it out :
Name = SIP ID eg 123456
Authentication Name = SIP ID eg 123456
Authentication Password = ****** (your PlusNet password)
Proxy Address = sip.plus.net
Proxy Port = 5060
This should be all that is needed. Here are a couple of optional fields:
Shortname = PlusNet (can be anything you want)
Display Name = PlusNet (can be anything you want - this is sent to other end of call)
Hope this helps someone. Cheesy
Cisco SIP Problems
Greate news to here u got it working... Im have problems authenticating... would u mind sending me a copy of ur config ex ur use ID's etc.. thanks...
