Compatible usb handsets
Can anyone tell me what usb handsets are compitable with X-Lite??
The X-Lite website only shows 2 but surely there must be more than that.
If you have purchased a cheap USB handset can you please please let me know Huh
Kind Regards,
Rab
rengarth
Hi
I bought this one from Argos
http://www.argos.co.uk/static/Product/partNumber/5521553.htm
I know it's supposed to be used with Skype, and the handset controls don;t seem to work with X-lite. But the mic and speaker on the handset do. It's not a problem to me that the handset buttons don;t work - I just dial on the numeric keypad on my keyboard, hit enter, and away I go Cheesy
Thanks !!
May just give it a go
orrery
I've read that Tesco do one for their VOIP service and that the drivers are downloadable. More information is on the newsgroup:
uk.telecom.voip
regards, Ian
orrery
... or the one on www.sipgate.co.uk is designed to work with X-lite.
regards, Ian
The Tesco Broadband phone does work with Plustalk, and using drivers I found on the internet (can't remember which site atm though) I got the display and controls working fine with it too.
I've given up with softphones now though as I can't find one that works properly with Vista yet.
