Change web site address
ampdef
How do I change my existing web address to my domain name? or can I?
do you mean The Arnold Chiari & Syringomyelia Information?
If you have bought a domian and its hosted with plus net from the portal you can set the folder on the server you want the new domain to point to. So the default webpage is in the fold htdocs so you could then create a dir in htdocs called acs and in th eportal tell the new domain to goto
htdocs\acs
This does give the option of having 2 web sites one www.username.plus.com and www.yourdoamin.co.uk. they could both be the same of differant.
ampdef
Cheesy Thanks mwright, I will try what you say :? and hope I don't screw up. I am new to this sort of thing and any/all help is much appreciated. Right here goes.
Thanks again
