Change IP
Change IP
Hi, is there a way to change the IP of my computer?
Change IP
Do you mean the IP allocated to you by PlusNet or the IP of a machine on a local network?
Change IP
um, I think the one allocated to me. It is the IP address shown when I go to www.whatismyip.com
Change IP
Ok that is the one allocated to you by PlusNet.
I assume you are on ADSL which gives you the same IP every time.
If you are on dial up then it will change every time you log on.
To request a change you need to use the link:Contact us facility explaining why you want it to be changed.
Change IP
I'll ask here... why do you want to change it?
