Cant login via ftp to my webspace
Just posting to you lot before i raise a call...
i'm trying to ftp a file to my webspace but having no truck...
Tried FTP explorer and normal cmd line FTP.
I login with my username - rooibos
And my password (same as I use to login to here at the Member Centre)
And i get Login incorrect - Login failed.
Any clues?
What server are you trying to login to. This should be ftp.plus.net with login/password the same as the portal here.
Yes sorry - ftp.plus.net and I've also tried the secondary ftp-proxy or summit. And I've also shutdown zone alarm. So... I dunno.
Microsoft Windows 2000 [Version 5.00.2195]
(C) Copyright 1985-2000 Microsoft Corp.
C:\Documents and Settings\Nick>ftp ftp.plus.net
Connected to ftp.plus.net.
220-PLEASE NOTE: If you have a non-subscription account you
220-will only be able to login to this ftp server if you are
220-dialled into our network.
220-
220-ALSO: If you upload a file whose size would cause you to
220-exceed your allocated disk quota, it will be automatically
220-removed.
220-
220 Plus.Net FTP Server #4 ready
User (ftp.plus.netSadnone)): rooibos
331 Password required for rooibos.
Password:
530 Login incorrect.
Login failed.
ftp>
Are you using all lower case for your password.
Are you absolutely sure you are using the corect password? try loggin out of the portal and logging in again
I know the ftp server is ok as I have just connected myself to the same one #4.
Is this the first time you have tried to access via ftp? if so I suggest raising a contact us ticket to get PlusNet to verify the ftp server has been setup correctly for your account.
It is the first time - thanks, i'll raise a ticket. It just seemed so simple, I thought i must be doing something stupid.
My webspace has been 'refreshed' and now it works. Thanks guys.
