Cannot get a Plusnet default hit counter to work
Hi
Website is at www.sunnymeade.plus.com
All of the website files are on my ftp webspace, I have CGI activated. I noted that pre-written hit counter scripts are available from plusnet and placed the html for the default counter on my home page as directed - but all that shows up when I look at the site is the html for the counter and not the counter itself. Can someone explain what I am doing wrong please ? I had assumed that I do not need to put anything into the cgi webspace if I use the plusnet scripts as they are just called from the plus.net cgi-bin
csogilvie
Your page currently says img src="http://homepages.plus.net/cgi-bin/counter?sunnymeade_pn" - it should have < and > around it to read <img src="http://homepages.plus.net/cgi-bin/counter?sunnymeade_pn">
csogilvie
Many thanks, that worked - knew it would be something simple I missed :roll:
