Cannot access my site using Frontpage
I cannot access my site using Microsoft Frontpage at the moment.
Is there a current problem or have some of the setting changed in the last month or two??
:shock:
Regards
Tom
lowry
I'm unclear on what your issue is. Do you have trouble accessing the frontpage space to upload your frontpage website to, or are you having trouble accessing your site on the frontpage site using your browser?
matt Wink
Yes I cannot access my site using Microsoft Frontpage to edit it. It was working fine a few weeks back. I can access the site OK with a web brouser but a form that uses Frontpage extensions is no longer working.
Its like the Fronpage extensions have been turned off but it says they are active in the My Accounts setting.
Regards
Tom
You need to raise a contact us ticket and get it investigated. There are no reported problems with the FP server accoding to service status so it may be just you with the problem.
