Can't pick up calls on my VOIP IP Phone
Can anyone help?
I have a Linksys IP Phone which my work has supplied me to work from home. This phone allows me to have 2 lines set up and I have successfully configured it to use my work's voip on line 1 and my Plusnet Broadband Phone on Line 2.
I can make calls with no problems at all. The problem I am having is that when someone calls me on my Plusnet number and I pick up the handset I can hear the person at the other end but all they can hear is the phone still ringing and then it goes onto the voicemail. I have also upgraded XLite to Eyebeam on my PC and it can't pick up the calls either.
Does anyone know how I can fix this.
Craig Stewart
1 REPLY
salts
Two things I changed when I had this problem:
Open port 3478 (STUN) on my routers firewall (plusnet mention this in their FAQ)
Port forward the relevent RTP & SIP ports to either your PC or your Linksys (5060-5070 & 8000 - 8010).
This fixed it for me, for obvious reasons incoming calls will have to go to either the Linksys OR your PC.
Paul
